I use the Embedded browser option when creating a website session. An example of my WordPress client. I create an Entry with a username and password, and leave the Auto Login and Auto Submit options checked by default. When I open the session, the registration form did not autofill and thus did not log in.
Is it a BUG or am I doing something wrong?
Best Regards,
Ljubomir Manojlovic
Hello wpCloudSolutions,
Thank you for contacting us on that matter.
Which version of RDM and what type of data sources are you currently using?
Which browser you are using?
Is it set by default in the web entry properties or in the File -> options in RDM?
Patrick Ouimet
Contrary to our web browser extension, RDM does not come with a page analyzer to discover credentials field on launch. You can either enter manually the fields ID in the Website -> Login tab of your web browser entry, or take your shot with the Discover button, although it's not guaranteed to work:
Xavier Fortin
Yes, that was missing part. For WP login, DIscover works perfectly.
SOLVED
Ljuba
Best Regards,
Ljubomir Manojlovic
Glad to hear it!
Do not hesitate if you have any other issues!
Xavier Fortin
