Need Assistance with PowerShell Script for Customizing Report in RDM
Hello RDM Community,
I'm trying to customize a report in RDM, specifically changing the text color for certain columns,add logo ect... I'm using PowerShell for scripting.
After Creating Report (Custom), I generated this script to add the required information.
Current Script:
```powershell
foreach ($connection in $Report.Connections) {
# Check if the connection is under the specified folder
if ($connection.Group -eq '#folder Path' -and $connection.Name -ne 'lizenzen') {
$Report.NewRow();
$Report.SetValue("Name", $connection.Name);
$Report.SetValue("Lizenzanzahl", $connection.DataEntry.SoftwareLicenseCount);
$Report.SetValue("läuft ab am", $connection.DataEntry.SoftwareExpiration);
Is there a way to customize the report with HTML code or add a template?
Thank you
Currently, there is no method in RDM to achieve what you want to do, using HTML encoding or a template to produce a custom report.
I have transferred this thread to the Feature Request section. It’s an opportunity for our community to demonstrate an interest in your idea. We use this interest to prioritize the features we implement.
Érica Poirier
