Showing User Expiring Credentials On Main Vault When Using SQL
Good morning.
Is there a way to show expiring User Credentials when utilizing SQL implementation?
Currently, when I log on, it shows the expiring credentials of assets which we don't utilize:
All the users have to switch to their User Vault in order to see if there are, in fact, any expiring credentials:
Is there a way to have this show on the main screen when connecting to the Vault so the user knows they have an expiring credential?
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.16.0 64-Bit - Free
Thank you for your suggestion.
We could most likely do this by adding a new widget "Expiring Entries (User Vault)". This widget would not be visible by default but you would be able to add it in the "Customize" menu of the dashboard.
I will open a feature request ticket for this and we will keep you updated on the progress.
Best Regards,
Michaël Beaudin
Best Regards,
This would be completely awesome! I just talked my organization in to purchasing license for a couple of our teams after using RDM for a couple years, and this is one thing that is keeping folks a bit hesitant on utilizing, since it is a PITA to reset our passwords in 10+ environments after they expire.
Thank you!
--- Chuck
