Synchronizer problem syncing to a different domain.
Implemented
HI,
I have some synchronizers setup and they work great for the domain I am logged into. However, we also have some other domains that we have access to. I tried to setup a synchronizer for one of those domains, but am having trouble getting it to work. I don't know if this is possible or not but here's what I did.
Set the mode to Custom and entered the fqdn of one of the domain controllers into the General tab. I verified I can ping the server just fine.
I went to the Login tab and entered my credentials for that domain. (Note: It'd be nice if I could link this to a credential in my vault so I don't have to come change it every time I change my password)
When i try to do a sync, or click the Test Connection button, I get an error that says Connection failed. The server is not operational.
Any idea what this means and if there's some way to set this up and get it working?
Thanks.
All Comments (7)
To clarify, I'm wondering if this was working for you previously or if this is a new configuration?
Perhaps you could provide us with a screenshot of your configuration? Please remove any sensitive information.
Let me know,
Samuel Dery
Hi.
I never tried this before since it was for a secondary domain. I figured since I can ping the domain and RDP to the machines via fqdn, that RDM should be able to sync to it. I just couldn't get it to work.
When I fill in a computer Name, after choosing Custom for the Mode, and click Test Connection, the test fails even though I can ping and remote into the machine without any issues.
Thanks.
We are also having this issue and it has been reported in Support Ticket : 00047950 for tracking. We get "bad username or password" when trying to AD sync from another domain. We have tested with support and LDAP communication is open and functioning to the secondary domain.
Thanks!
