Problem duplicating credentials entry and pasting password
Hello, i have not completely figured out how and when this happens, but it happened several times the last days
I copy a credentials entry to another folder by right click -> duplicate, paste a different password or have one created and then save the entry.
Then this happens :
I'm not totally sure, but i think it startet after the update to DVLS 2023.3.x and RDM 2023.3.x
Currently running DVLS 2023.3.10.0 and RDM 2023.3.31.0 64-bit on Windows
All Comments (1)
Hello hoppe,
In the 2023.3.x version of RDM, a move action resulted in an issue with the software. To address this problem, the feature was disabled in the 2023.3.32 version of RDM while the developers worked on fixing it.
Can you check the web interface of your Devolutions Server to confirm the password value was set to the correct value? It's possible that someone clicked "ok" after opening the entry's properties, which saved an invalid password. If this is the case, you can retrieve the previous password from the entry's password history and change it back to that value.
The team is currently investigating whether this process can be automated. Our apologies for any inconvenience.
Richard Boisvert
