PasswordState Entries with OTP not working anymore
At some point with either upgrading PasswordState or Devolution RDM our PasswordState entries in RDM with OTP no longer works.
RDM does not retrieve either the username, password or OTP. If i in PasswordState disable the OTP. The RDM entry are able to retrive username and password again. This has been working for a long time, but as said just stopped working at some point.
RDM Version: 2023.3.28.0
PasswordState Version: 9.8 (9823)
Both newest versions.
Hello mka,
Thank you for getting in touch with us regarding this matter.
Can you please confirm if the entry is functioning properly?
Also, please try creating a new entry PasswordState and manually enter your OTP.
Lastly, could you provide information if there were any changes made to the API from one version to another on the PasswordState side?
Patrick Ouimet
Hi Patrick,
I have tried recreafting the the entry from new and I have tried having the "Allow OTP retrieval" checked and unchecked. But as long as there are a OTP code in the password in PasswordState I cannot seem to get it to work in RDM.
The following was changed in PasswordState in version 9.8 - Build 9811
  • Included OTPUri field in response for the API endpoints when retrieving password records
Hello mka,
To investigate this issue, I've sent you a link to schedule a session with me.
Patrick Ouimet
