Host not shown in description when using Inherited for RDP entry
Backlog
Hi
RDM: 2023.3.25
DVLS: 2023.3.6.0 (Not the newest, but my assumption would be that it is RDM related?)
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
I've been able to reproduce the behavior on my end, after discussing this with our development team, we've created a case to see if this can be implemented which I've linked to your topic,
I will keep you updated with any news I receive regarding this,
Samuel Dery
Hello! We have recently started using "inherited" for RDP entries like OP, and we have the same issue, so I am curious if there are any updates. Our semi-workaround is to not use "inherited" specifically on the entries, but use "custom" and then use "$COMPUTER_IP$" as the host. This still inherits the host from the folder when connecting, and it at least shows the port in the description.
However, our ideal case would be if we chould show both the IP-address and port in the description, like it would when you use "custom" host. After all, it shows the inherited credentials with no problem.
Our RDM version is 2023.3.36.0.
Jonas Grandt Bindslev
Operations Consultant
Complea A/S, Denmark
Hello Jonas
Thank you for your reply,
I do not have any news regarding this at this time, I've reached out to our development team to see if they could provide us with an update regarding this,
Samuel Dery
