System Vault: Central/Global Credentials?
DVLS: 2023.3.5.0
RDM: 2023.3.24.0
Hi All
The Sytem Vault is awesome, thanks for that.
But is it possible, to add Central managed Credentials?
In our Case, we have a global SSH Gateway. This Gateway uses the same connection Credentials over all Vaults.
Currently the Credentials are Scripted, but would be nice, if we could use a central Credential Object for that.
Is this possible?
29a3e9fc-4d08-4b9c-ba62-c4c964942ab0
Best Regards,
Andreas
Hello Andreas,
It is not possible to have credentials in the System vault, unfortunately.
I have moved your thread to the Feature Request section instead!
Richard Boisvert
I'm curious to know something. We have no security granularity in the global vault. This means that the credential will be available to everybody. That's why we are not sure if we want to allow credentials in the global vault. What do you think?
Hi David
I see the Point with the Security. But in my opinion it doesnt matter, because all Users which has access to the specifig Entry could See the Password Plaintext in the specific Setup.
Thats why im asking for a central Credential Management for easier handling.
Best Regards,
Andreas
Edit: How about simply implementing the same Permission System as on regular Vaults to use AD/Azure Groups for accessing System Vault Entries?
