2023.3.20 - Credentials entries sourced in Devolutions HUB Personal not working
Implemented
Hi
Windows 11 x64 23H2 (Build 22631.2506)
RDM 2023.3.20
DVLS .2023.3.5
When I try to use an entry which uses credentials which is retrieved from HUB Personal (Account is migrated and works) I an sent to a "Sign up" for HUB personals page instead of RDM trying to login.
The same happens if I edit a credentials entry and select ... to see the HUB Personal credentials list
RDM itself is connected, and if I log out, can log in again, so it seams the integrations isn't updated to work with the ned HUB Personal.
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
All Comments (14)
Having issues with using the Personal Hub as a source post-migration as well.
I just came across this message on the RDM Dashboard after everything was greyed out trying to modify any entry and finally, everything vanished upon trying to refresh the source.
"The Hub version (0.0) and Remote Desktop Manager version (2023.3) are mismatched. Your datasource is in read-only mode."
Not sure what the timeout on the authentication session is or if it's supposed to use the offline capability or not but the current behavior is fairly disruptive.
Hello sbush,
Would it be possible for you to validate if this issue persists on RDM 2023.3.22.0?
This version can be downloaded here:
https://devolutions.net/remote-desktop-manager/home/thankyou/rdmsetup/
James Lafleur
Hello nOrphf,
Our Development Team just informed me that the issue you reported should be fixed in the next version of RDM.
James Lafleur
Thanks, I've updated and will see how the Hub data source behaves.
Sorry, dosn't work in .22 either :(
Hello Norphf,
My apologies, I mean't 2023.3.23.0.
James Lafleur
Oh, I see :D - Thanks
is version 2023.3.23.0 available now?
Best Regards,
Mariusz
Best Regards,
Mariusz
I can see that 2023.3.24 has been released now.
And I can confirm that on my setup it works.
Thanks for your reply
Hello everyone,
Thank you for your respective feedback! We are glad to see that this version works for you.
James Lafleur
I am getting the same error: "The Hub version (0.0) and Remote Desktop Manager version (2024.1) are mismatched. Your datasource is in read-only mode." I have upgraded to latest version of RDM. What can be done to resolve this issue?
@jaredshaleen,
We will continue with you regarding this issue in thread https://forum.devolutions.net/topics/42084/the-hub-version-00-and-remote-desktop-manager-version-are-mismatched-y
We already responded yesterday inside that topic.
Ends in 13 days
