I am attempting to switch an RDM website that is currently working when using Chrome to Edge or Internet Explorer, however when I make the change the page does to load. When using Edge the URL once connected reverts to 'localhost'.
As am example if I enter the following as the URL
When I connect it will attempt to load as:
This will only happen when it is set to edge, if I change it to use Chrome the site load as expected.
I think the issue is to do with the way we have it setup, we use a jump host to connect to our private network at one of our sites. There is an option in the 'VPN/Tunnel/gateway-->Settings (SSH Link)' settings to 'Force "local host" but I cant change it as it is greyed out because 'Use over secure gateway' is enabled. If I untick 'Use over secure gateway' it tries to connect using the correct URL but fails because it is trying to access the site over the public internet when my site can only be accessed from within our network.
Like I say, as soon as I change the browser to Chrome the site loads without any issues.
Other than only being able to use Chrome is there any way round this?
Current RDM version - 2023.2.33.0 but I had the same issue on 2023.2.14.0 and 2023.2.32.0
If you need any more information let me know.
To better assist you, could you please provide the data source you are using and if the issue reappears if you change the display
option to external?
Once we receive this information, we will be better equipped to diagnose and resolve the issue.
Would it also be possible for you to create a portable installation of RDM and see if this issue still occurs? To do so, you will need to do the following:
1. Download the .zip file below: https://remotedesktopmanager.com/home/thankyou/rdmbin
2. Create a new folder on your Desktop.
3. Extract the content of the .zip file into the folder created at #2
4. Go to this folder once the .zip file has been extracted and run remotedesktopmanager64.exe
5. Connect to your data source.
This will tell us if the issue is tied to the local installation of RDM.
Thank you in advance for your help, and please don't hesitate to reach out if you have any questions or concerns.
Carl Marien
