Implemented
Alternate Way to Hide Sessions
We currently use RDM to establish an RDP session to various servers. Within those sessions we often give remote users access to the server. Once we give them access we hide the session so they can't continue to control the mouse curser on our end as they work. Well currently, the only hide button is in the drop down menu when you right-click the session tab. This drops the menu over the session window. Once you try to move the cursor over the menu to select hide, you are fighting with the remote user for control of the cursor a lot of times.
Can we have the hide option added to the menu that you access when right-clicking the session in the Navigation Pane; or can you add a hide button to the Ribbon which will hide the currently selected session?
All Comments (5)
I think adding it to the ribbon in the Actions tab would be a good idea. I have opened a ticket so we can add this.
That would be awesome. Thank you!!
We've added the Hide button to the Actions ribbon section. This will be available for the upcoming 2024 version.
Jafran Majeau
That it awesome. Thanks!
Any ETA on when that version will be released?
Assuming there are no major issues, the release should happen next week (or the following one after that). This is not a guarantee, but rather an "expected timeline", which we are on track for so far.
Jafran Majeau
