RDM 2023.2.28.0 64-bit not opening sessions with display "External"
Implemented
Hi all,
as title I have the problem that opening sessions with display "External" closes immediatly.
example:
This is the log:
as you see I have this problem from days. Trying using for example "Undocked" works
how can I resolve?
All Comments (7)
An internal ticket has been created for an issue that appears similar to yours. To confirm whether your issue is related to the other one, could you please perform the following tests or answer the following questions?
1.     Have you installed the latest version of Windows (KB5030219)?
2.     Could you try disabling RDP API hooking and then restart RDM to see if it resolves the issue? For instructions, please refer to his link: https://docs.devolutions.net/kb/remote-desktop-manager/knowledge-base/microsoft-rdp-api-hooking
3.     If disabling RDP API hooking doesn't help, please re-enable it. This time, turn on the RDP logs provided by RDP API hooking to help us better understand Microsoft RDP's internal behavior. For instructions, please refer to this link: https://docs.devolutions.net/kb/remote-desktop-manager/knowledge-base/microsoft-rdp-api-hooking/#microsoft-rdp-logging
If you have any further questions, concerns, or require additional support, please don't hesitate to let me know. I'm here to assist you.
Carl Marien
  1. Yes
  2. Disabling api hooking made it work again with external settings, thx
Can you tell me the difference between external and internal RDP? wich is the most stable?
Are you referring to the distinction between "external" and "undocked" sessions?
  • "Undocked" refers to sessions that RDM initiates but displays in a separate window.
  • "External" implies that another application is responsible for launching the session.
Carl Marien
We have also experienced this since KB5030219. Will there be a more permanent solution than disabling API Hooking?
Our development team is actively working on resolving the issue you've reported. We will keep you updated on our progress.
Carl Marien
I meant the difference between the external application and the "internal" (undocked or docked) RDP application.
What's the key difference?
I apologize for the confusion.
To clarify, there is no functional difference between the "undocked" and "docked" modes. There is no version that is more stable than the other.
Carl Marien
