Smart Reconnect with many sessions
Resolved
Let's say I have around 30 sessions open. I also have them set up Display - Screen sizing mode "Smart reconnect", and under Advanced - Reconnect mode "Smart Reconnect".
When I start opening sessions, once the tabs wander into a 2nd/3rd/etc row, apparently all sessions start to reconnect to adjust the screen. I think that is happening, because all sessions hang for a while, however RDM doesn't freeze.
What I would like:
Only to smart reconnect when I click on the tab of the specific session, other tabs should not reload/reconnect in the background.
What do I have to set?
Thank you
Srdan
All Comments (2)
Hello Srdan,
Thank you for contacting us on that matter.
I did some tests, and the active time stays the same for the inactive tab.
Could you send some screenshots or explain the reconnect behaviour more precisely?
Patrick Ouimet
yesterday, for unknown reason, I got no hangs and background sessions performed as expected.
I will report if things go sideways again.
Thanks
Srdan
