Problem with Command Line connection type
I can remotely control most of my servers with RDP and VNC
However, some servers have a different program installed for remote connections (NetOP, Remote Administrator).
For this, I can use the 'Command Line' connection type. I have experienced that there is a problem with the command line type when the path to the external program to execute contains 'long' folder names (e.g. C:\Program Files\Radmin Viewer\Radmin.exe). The program can't be executed. When I omit long folder names (eg. C:\Tools\Radmin.exe); the program executes as expected.
Could this be a little bug in Remote Desktop Manager?
As a workaround; I created a 'short' folder on my local drive (C:\Tools) and created cmd-files in it that starts the application. The cmd-file can be succesfully executed from Remote Desktop Manager. No very nice; but it works for now...
All Comments (1)
Sorry for the bug, you are right, it's fail. I will fix it in the next minor update. Actually, I already did the fix, I can send you an unofficial version if you want, just email me at support@devolutions.net if you are interested.
Have a nice day
Devolutions inc.
Closed
