Platform: Windows 10 Enterprise
RDM : 2023.02.18.0
Forticlient: 7.0.9.0493
Forticlient does not start while it's configured
We tried the command line, forticlient.exe and ipsec.exe, we also tried custom VPN
Nothing seems to work
I'm available to test or try anything that you guys would have in mind
Thank you, I will speak with my team and look into this.
I will update you soon.
Hi Zachary,
any update on this post?
David
At the moment, we are still unable to update the integration. If you are able to provide a command line or an SDK, it might be possible, otherwise, we cannot advance on that.
Etienne Lord
Hi Etienne,
How could be able to provide that? I don't understand how I can provide an SDK for forticlient.
This is the usual question we ask. As a developer, I can't do any integration if I can find an SDK or some command line parameters. Unfortunately most VPN executable and documentation are gated. From my experience, IT people are good at finding way of integrating those tools with script. You could ask, why we don't do ourself the search? The answer is simple, it's just nearly impossible to investigate all the suggested products.
