website embeded login problem
Resolved
dvls : 2023.2.5.0
rdm : 2023.2.22.0
for some reason auto login fill is working for website legacy entries while for new website entries auto login fill button is grayed out.
while same thing but legacy
I have noticed for several versions ago but didn't had time to play with it.
Do you have ide what to test/try to fix this issue?
Darko Bazulj
https://triton-grupa.hr
All Comments (4)
Dear Darko,
Thank you for reaching out to us regarding your concern.
We would like to inform you that to auto-fill your embedded web page, and you may refer to this article: https://docs.devolutions.net/kb/devolutions-web-login/how-to-articles/website-authentication/#automatically-log-into-a-website.
I tested it on my side, and the website entry with the autofill configure has this auto-fill option.
Could you have a look at this and tell me if this issue still occurs?
We hope that this information is helpful. If you have any further questions or concerns, please do not hesitate to let us know.
Patrick Ouimet
Hi Patrick,
[Discover] under [HTML Control ID] was a fix in this situation.
After that [Autologin] works or if I uncheck [Autologin] key button is available to fill data.
Now I have question why this is needed if I open page in embeded mode while if I open page in external mode [Devolutions Web Login] knows how to fill login data fields.
Darko bazulj
Darko Bazulj
Dear Darko,
Thank you for sharing your feedback with us.
We would like to inform you that Remote Desktop Manager utilizes a third-party library from the browser, which does not allow us to share the same information. As a result, Devolution Web Login cannot be used in RDM. However, our Extension Manager Tools can be used to open an external webpage and install the necessary tools.
Patrick Ouimet
Hi Patrick,
I have also found that is possible to convert website (legacy) to website entry and then do discover HTML autofill and multiple entries at onece.
https://docs.devolutions.net/kb/remote-desktop-manager/how-to-articles/convert-website-legacy-to-website/
Thank you for help.
Darko Bazulj
Closed
