I have a RDP configured to open in external (general -> display -> external and secondary monitor), but it always open on the monitor where Microsoft RDP Client is positioned in MacOS.
Is there any configuration I can change to always open in selected monitor, disregarding the monitor where MS RDP app is opened?
Thank you.
Thanks for contacting us regarding this,
Out of curiosity, if the MS RDP app is closed when you run the RDM entry, does it then open in the secondary monitor ?
No. MS RDP opens in primary monitor and so does the external RDP session window.
Also, I have, under RDP config of the connection, in display settings, set to Remote Desktop size: full screen.
Thanks for confirming and the added details,
Which version number of RDM MacOs are you currently using ?
the version is 10.8.4 (2111)
The latest version of RDM MacOS is 2023.2.8.1, could you update to this version for me if you haven't yet ?
I have the latest version available in Mac App Store: 10.8.4.
It seems this is for Microsoft Remote Desktop, however I'd like to if you're using Remote Desktop Manager from Devolutions ?
If so, I'd like to know the version you're using. The latest version for the MacOS application is 2023.2.8.1 and the version number you're using (if you're indeed using RDM) can be found under Help > About, or alternatively at the bottom-right corner of the application.
If you're not using Remote Desktoip Manager then there is unfortunately nothing we can do to help, as we do not handle Microsoft Remote Desktop.
I apologise for my confusion.
Yes, I'm in the latest version of Devolutions RDM: 2023.2.8.1
Thank you for confirming this,
I will see if we can reproduce this behaviour internally and get back to you with my results.
Hi telmop,
Unfortunately, this is not supported. When we launch a session externally, we simply create a .rdp file and make Microsoft Remote Desktop open it. What it does with it, how it opens the session and where is from then on out of our control. If you want to chose the screen where the entry opens, I would suggest using the Undocked mode.
Xavier Fortin
I changed to "undocked" with no change.
Double click e it continues to open externally and using Microsoft RDP Client.
