For the Xshell plugin , is there a way to use Xagent for authentication?
I have a few questions which you can hopefully answer.
That being said, from quickly looking at the Xshell entry "Properties" it seems to be started externally using command lines. I'm wondering if using the "Shared Session" and pointing to the "Shared config folder" may work for you in this case?
Could you give this a try and let me know,
Samuel Dery
Samuel Dery , thanks for the quick reply :
background info :
RDM Version = 2023.2.22.0 64-bit
Data source = local data source .
"I'm wondering if using the "Shared Session" and pointing to the "Shared config folder" may work for you in this case? "
Is there a way to integrate Xshell for RDM so that any scripts/ macros created in RDM can run on an Xshell instance ?
If not then , is there a way to force the usage of Xagent for authentication ?
Thank you for your reply,
That is correct, from my understanding, RDM is simply using commands line to launch this application,
I'm wondering if there is a specific reason why you're not using the SSH Shell entry type in this case?
Let me know,
Samuel Dery
