How to manage data sources for users in RDM.
Is there a way that the data sources are automatically created for the users? Like via GPO, copying config files,...
All Comments (4)
I see, indeed you could include the data source configuration in a custom installer of RDM, we have the following knowledge base article regarding custom installers:
https://docs.devolutions.net/rdm/windows/installation/client/custom-installer-service/
Alternatively, you could generate an export of the data source configuration that your users can import, we have the following knowledge base article regarding this:
https://docs.devolutions.net/rdm/windows/commands/file/data-sources/#importexport-data-source-configuration
Let me know if this helps or if you have further questions regarding this,
Samuel Dery
I think it would be easier to use this:
Terminal Services / Remote Desktop Services - Devolutions
That´s the way we do it. Creating a Custom Installer for every version makes no sense, a file can be easily distributed to all clients.
Brgds Andreas
Thank you for your reply,
Indeed if you're in a Terminal service environment, then using the Default.cfg method would work as mentioned by Andreas.
Samuel Dery
not only in a terminal server environment - also for normal workstations I think this is the best solution so far. Because I don´t need to rebuild the base setup every time a new version comes out.
The best solution would be, to provide all those settings via GPO... :)
Brgds Andreas
