is there a way to view an XML document within RDM
Implemented
I can add an XML document to RDM, and it will be opened with default editor outside the RDM, just wondering if there is a way to do the same within RDM as a tab?
Thanks!
Could you try to open your Xml document in Microsoft Edge? If it's good enough for you we could open it embedded in RDM using the WebView2 engine which is Microsoft Edge.
Hello David,
Yes, I can open it in Microsoft Edge. It looks good. The purpose of opening this XML is to read the content in this case searching for a license key.
Thanks!
Murat
Perfect,
We will create a ticket for that.
