Implemented
Focus input to OTP input field
When you're using an OTP authentification and you start a fresh connection the OTP input window appears.
It would be great if then the input foucs is automatically in the OTP input field. Actually you must put the cursor with the mouse in that field to fill in the OTP code. So please change the focus from the OK button to the input filed.
Thanks,
Christian
Could you give more information to how you reach this window? It will be easier for us to make the change if we know exactly which window this is.
