syntax highlight doesn't work correctly if regex match is split into multiple lines
Hello time. I am on 2023.1.29 and I am using syntax highlight for my SSH sessions.
I found that, sometimes when a regex match for syntax highlight is split into multipole lines, syntax highlight only matches the part on the second line.
below screenshot explains same text. I am using syntax highlight to hilight date/time.
in first screenshot, timestamp is hilighted correctly.
if I increase the font, the line will split into two lines and here we see it only matches the part that is on second line, while the first line color isn't changed.
I hope you may fix this issue.
Best,
Andy
Thank you for contacting us,
Do you get the same behaviour on the latest version ? (2023.2.14.0)
I tested now with portable 2023.2.14.0 and issue seems fixed on this version.
Thank you Zachary.
My pleasure !
I'm glad the update resolved your issue.
