RustDesk and advanced parameters
Hello.
I have questin about RustDesk add-on and posibility set advanced parameters as ID Server, Relay Server and Key.
Will you plan implementation these advanced parameters for RustDesk add-on in future releases?
Thank You for reation.
Best regards, Ales
I will verify with our engineering team if it's possible but I'm not sure that the RustDesk command line we use allow such parameters.
As a workaround, you could use the Custom fields to fill in these fields. And then use the Typing macro feature of the After Open Event of you RustDesk entry.
Let us know if that works on your end.
Érica Poirier
Hello.
I did not find command line parameters for windows client of RustDesk application.
But I found solution with modified exe file name by this instructions:
https://rustdesk.com/docs/en/self-host/install/#step-3--set-hbbshbbr-address-on-client-side
section: Put config in rustdesk.exe file name (Windows only)
If there will be possibility to set custom file name of RustDesk client exe file in settings of Remote Desktop Manager (File - Options - Paths - Configure Installation Path - RustDesk -- now it must be rustdesk.exe)
this will be solution of this problem.
Thank You for Your response.
Best regards, Ales
Thank you for sharing this information.
Following a discussion with an engineer, I can create an internal ticket to be able to update the EXE file name in File - Options - Paths - Configure Installation Path - RustDesk. Please note that RDM won't modify this parameter automatically. You will have to modify it manually.
Let us know if that solution is viable for you.
Érica Poirier
Closed
