Connection shortcut
Hello.
I was trying to find is it possible to create connection shortcut on the desktop but without success, so now I asking a wider audience for help.
My problem is that I have one (out of many) connection that is very important to me and I was wandering is it possible to have a icon on my desktop to start that specific connection without me opening RDM and then selecting it from list of my connections? It is a VMRC based connection.
Hi ratko,
Yes, this is possible. Simply open the entry properties (as if you wanted to edit), go to the Entry Information tab and click on the "Create Desktop Alias" button:
Xavier Fortin
Xavier, thanks.
That is exactly what I needed!
Ratko
Glad to hear it!
Do not hesitate if you have any other questions!
Xavier Fortin
Ends in 10 days
