Save Templates and Favorites when exporting Vault to RDM v2
Good morning all.
Is there a reason why the Export Vault feature cannot be updated to include Templates and Favorites when exporting to an RDM file?
I mean if someone needs to Export the vault to an RDM file, it should backup everything done.
In troubleshooting for the "can't create backup" issue, I exported my vault to an RDM file, and completely forgot the Favorites and Templates aren't included.
It is a PITA to go back through and remember what all was there over the course of the last year.
Thanks!
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.16.0 64-Bit - Free
What data source type do you use? We try to include as much information in the export but this is not a backup file. It would be easier to backup restore a SQL Server database instead.
I am using the available SQLite.
--- Chuck
I think in you case it could be simpler to just copy the .db files for a full backup.
OK. That makes sense.
Also, something new I found after my 2nd day of searching... LOL
The Online backups that are automatic when an entry is modified, added, deleted, etc., include a full DB backup?
--- Chuck
Hello
The online backup is only a simple export of the current vault and it's not a full backup. We have on our internal roadmap to improve the backup system to export to a local file that could be synchronized on your own file cloud (DropBox, OneDrive, GDrive...) and I will try to include a full backup at the same time.
