Im having problem with multiply computers on the same lan, that suddenly stopped syncing,
we all share the same datastore, Devolutions Online Drive, its was working just fine until a week ago,
I tried to log off, and re-entering the account, but new created things doesnt sync, Its working somtimes only when exiting the RDM and re-entering it, but sometimes this solution doesnt work either.
is there solution for this problem? thanks ahead!
What RDM version do you use exactly?
Could you try update to this version? It's could also be a good idea to migrate your data to Devolutions Hub Personal.
https://cdn.devolutions.net/download/Setup.RemoteDesktopManager.2023.1.29.0.exe
Hi david, were all running the same version, 2023.1.29.0 64-bit
Thank you for your swift reply!
As per your initial post, you are all sharing access to a single Devolutions Online Drive, is this correct? If so, it is important to note that this type of data source is meant to be used by a single user. If you wish to share it with multiple users, I would recommend opting for an advanced data source instead https://docs.devolutions.net/rdm/windows/data-sources/data-sources-types/advanced-data-sources/.
Also, as a side note, the Devolutions OnlineDrive has been deprecated in the latest version of RDM. To see more on that matter, please refer to this blog post: https://blog.devolutions.net/2023/05/why-we-recommend-devolutions-hub-personal-instead-of-devolutions-online-drive-as-a-data-source-in-rdm/
James Lafleur
Thanks james, i will check that out !
You are more than welcome!
Let us know if you require further assistance.
James Lafleur
