I'm new user on RDM.
I want to ask abiut quick connect bar.
I can't find how to set this.
I saw some people have something like this
I know i can use Shortcut but i prefer something like this :)
Any chance to bring this back?
Reset Layout and Ribbons doesn't work
Thank you for contacting us.
I appreciate your inquiries, and I'll be glad to assist you. To provide the best support, I kindly ask you to provide the following information:
Regarding the issue with the reset layout not restoring the default view, it does seem unusual. To investigate this further, I would like to confirm your version and conduct a test using a portable instance of RDM.
Please feel free to share the requested details. Should you have any additional questions or concerns, don't hesitate to let me know.
Samuel Dery
I think that the issue is that you use the menu and not the ribbon.
It's not possible to have a toolbar in the title with this mode. The second print screen is a ribbon in Show Tabs Only
That helps!
Thanks! :D
Thank you for your reply,
I'm glad to see that the suggestion by David resolved your issue!
Let me know if you have further questions,
Samuel Dery
