Using the Multiple Monitor Span Display in Remote Desktop Manager
According to this article it was possible to span on multiple screens if possible but from the version we run I cant see this option from the Display settinsg - we running version 2023.1.26.0
Is there a way that RDM connect in fullscreen using 2 display or more at the same time for the unique RDM connection?
Thanks
https://blog.devolutions.net/2021/07/feature-spotlight-using-the-multiple-monitor-span-display-in-remote-desktop-manager/
Hello Steve,
The option is still available, in the same location. First, make sure you change the display to "External", and then the option will be available:
Richard Boisvert
Thanks - that's the part I was missing.
Hello Steve,
My pleasure, glad it solved the issue!
Richard Boisvert
