quick launch option using Private Vault entries
Backlog
I would like an option under quick connect to select a credential from my private vault for authentication. Or the ability to right click on an entry in the private vault, select "quick Connect" then prompted for "RDP/SSH/etc" then a dialoge for IP/hostname and a connect button to use it.
Thank you for your request. I have opened a ticket and we will see what we can do to enable this workflow.
The closest thing we would have right now is for you to create a template that uses the "Find by name (user vault)" credential option, then use that template in the quick connect, but I understand that it's not a very convenient solution.
Hello, just wondering if there was any any update on being able to add this to the product? This would also be very useful for us...
Best regards
David Willis
There is no update for now, but I will see if we can raise the priority on this. Thank you for your feedback.
Closed
