Remote Desktop Manager
Search option / List option not showing on left hand side like previous
Search showing at top bar
All Comments (4)
Would it be possible for you to go under the "Window" section of the ribbon of RDM, use the "Reset Layout" and see if it brings back your search bar?
If it doesn't work, could you please confirm if this change occurred after updating RDM? If so, on which version of RDM were you prior to this update?
James Lafleur
Hi James,
I have managed to resolve this thanks for your help.
Thank you for letting us know!
Do not hesitate to contact us again if you require further assistance.
James Lafleur
Hello Danny,
Are you encountering the same issue? Have you tried to use the "Reset Layout" feature?
James Lafleur
