Use the same SSH session/channel for SFTP
Implemented
Would it be possible to establish an SSH channel for SFTP using the existing connection?
When connecting to an SSH session via an Azure Bastion VPN/SSH/Gateway, it is not possible to establish an SFTP connection at the same time. I have enabled the "Use SFTP connection for remote file transfer" setting under the Advanced Terminal settings, but when I connect, the remote server area in RDP is just blank.
It would be cool to use the same SSH session/channel for SFTP, but I also wouldn't mind if it initiated another Azure Bastion connection for SFTP. Either way it would be great to be able to do SSH and SFTP at the same time with Azure Bastion connections from within Remote Desktop Manager.
Original discussion regarding SFTP using Azure Bastion in this thread: RDP via Azure Bastion (native client)
Thanks,
Aussie Davo
All Comments (4)
Hello Aussie,
Thank you for you reaching out to us regarding this,
I wanted to inform you that I've reached out to our engineering department regarding your request and will keep you updated with any news I receive,
Samuel Dery
Just to let you know, we have opened an internal ticket for this request. We will post back in this thread once we have an update.
Hi Hubert,
Thanks for opening an internal ticket for this. I'm really looking forward to this feature working :)
Kind regards,
Aussie Davo
Hi Hubert and Samuel,
Just letting you know that I downloaded and tested version 2023.2.9.0 (June 20, 2023) today and SFTP over a single SSH connection now works as expected using Azure Bastion.
Thank you so much for arranging this :)
Kind regards,
Aussie Davo
