It ist possible to connect to a running session (scaling is not working correctly -> with horizontal and vertical small bar ) but not to create a new session. I see the MS Session Manager is trying to create the session but without luck. Windows Terminalserver 2019. RDM worked fine the last years so it looks like an update (RDM or on MS) has raised this issue. Can someone support?
Hello
Sorry to hear about the trouble connecting. I'll try to reproduce this on my side, but in the meantime it would help if you can generate a diagnostic log. You need to enable session logging as described here. Then, try to connect to your server - creating a new session, which we expect not to work - and afterwards, send the log file to us. You can either send it to me direct in a PM or to support@devolutions.net (mentioning this forum thread).
Please let me know if something isn't clear or if you have further questions or comments.
Thanks and kind regards,
Richard Markievicz
Hello again
I did just try this on my side (establish a new RDP session to a Win2k19 server) and it worked well on my side. As well as the diagnostic information I asked in my previous post, can you share some information about your setup? What version of RDM are you using (Remote Desktop Manager > About...)? Are you connecting directly to the server, or are you using an RD Gateway?
Richard Markievicz
Thanks for the fast reply. RDM 2023.1.7.1 and i am not using a RD Gateway on my Mac (macOS 13 Ventura)
I will post the logs when i am back in the office today
Hello
Thank you for the update. Since this scenario seems quite straightforward, and I'm unable to reproduce locally, the session log will be important to understand what's going wrong.
Please don't hesitate to post back if something isn't clear or if you have further questions.
Kind regards,
Richard Markievicz
[19:07:08:947] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:951] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:960] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:969] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:971] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:977] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:994] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:999] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:002] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:008] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:024] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:08:027] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:09:292] [15807:70b9b000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:07:09:292] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:09:338] [15807:70b9b000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Save Session Info Data PDU (0x26), length: 624
[19:07:09:338] [15807:70b9b000] [DEBUG][com.freerdp.core.info] - [rdp_recv_logon_info_v2]: LogonInfoV2: SessionId: 0x0000009A UserName: [user] Domain: [ad]
[19:07:09:338] [15807:70b9b000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Save Session Info Data PDU (0x26), length: 630
[19:07:09:338] [15807:70b9b000] [DEBUG][com.freerdp.core.info] - [rdp_recv_logon_info_extended]: LogonInfoExtended: fieldsPresent: 0x00000001
[19:07:09:338] [15807:70b9b000] [DEBUG][com.freerdp.core.info] - [rdp_read_server_auto_reconnect_cookie]: ServerAutoReconnectCookie: Version: 1 LogonId: 154 SecurityVerifier: 010C6A7CEF789020747D914E58E8D290
[19:07:09:346] [15807:70553000] [INFO][com.freerdp.channels.rdpdr.client] - [device_announce]: registered [0000drive] device #1: ppk (type=8 id=1)
[19:07:09:422] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:09:792] [15807:70b9b000] [WARN][com.freerdp.core.autodetect] - [autodetect_recv_request_packet]: Received a [MS-RDPBCGR] 2.2.14.1.1 RTT Measure Request (RDP_RTT_REQUEST) [RDP_RTT_REQUEST_TYPE_CONTINUOUS] message but support was not enabled
[19:07:10:306] [15807:70b9b000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
Hello
Thanks for the update. Sorry for the trouble, but is the log file complete? In the list of session logs, you should be able to right-click and "Reveal in Finder" and attach the complete file to the forum or an email.
Richard Markievicz
[19:20:42:921] [15954:6dd7b000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:42:923] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:42:923] [15954:6dd7b000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:42:924] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:42:924] [15954:6dd7b000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:42:924] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:42:924] [15954:6dd7b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:42:924] [15954:6dd7b000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:42:125] [15954:6dd7b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:43:278] [15954:6dd7b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:43:428] [15954:6dd7b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 475
[19:20:43:428] [15954:6dd7b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:43:430] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:43:432] [15954:6dd7b000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:43:443] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:43:459] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:43:459] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:43:459] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:43:459] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:43:459] [15954:6dd7b000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:43:488] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:43:489] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:43:489] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:43:500] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:43:500] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:43:500] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:43:500] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:43:501] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:43:515] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:43:530] [15954:6dd7b000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:43:530] [15954:6dd7b000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:43:530] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:43:530] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:43:530] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:43:542] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:542] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:553] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:553] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:564] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:564] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:575] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:575] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:586] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:586] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:597] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:597] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:608] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:608] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:620] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:620] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:631] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:631] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:642] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:43:642] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:43:653] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:43:653] [15954:6dd7b000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:43:654] [15954:6dd7b000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:43:654] [15954:6dd7b000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:43:654] [15954:6dd7b000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:43:654] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:43:667] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:43:667] [15954:6dd7b000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:43:667] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:43:736] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:43:737] [15954:6dd7b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:43:737] [15954:6dd7b000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:43:738] [15954:6dd7b000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:43:738] [15954:6e7df000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:43:740] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:43:756] [15954:6dd7b000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:43:756] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:43:756] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:43:756] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:43:756] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:43:756] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:43:769] [15954:6dd7b000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:43:772] [15954:6dd7b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:43:772] [15954:6dd7b000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:43:794] [15954:6dd7b000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:43:794] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:43:794] [15954:6dd7b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:43:794] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:43:794] [15954:6dd7b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:43:794] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:43:794] [15954:6dd7b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:43:795] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:43:795] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:43:795] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:43:795] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:43:795] [15954:6dd7b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:43:795] [15954:6dd7b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:43:802] [15954:6ee27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:43:802] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:43:802] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:43:803] [15954:6ee27000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:43:803] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:43:803] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:43:803] [15954:6ec1b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:43:806] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:43:806] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:43:817] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:43:817] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:43:817] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:43:817] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:43:818] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:43:818] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:43:181] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:43:181] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:43:181] [15954:6ec1b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:43:181] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:43:181] [15954:6ec1b000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:43:181] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:43:193] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:43:193] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:43:206] [15954:6e7df000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:43:207] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:43:207] [15954:6ec1b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:44:305] [15954:6e7df000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:44:305] [15954:6e7df000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:44:305] [15954:6e7df000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:44:305] [15954:6e7df000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:44:305] [15954:6ee27000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:44:305] [15954:6ee27000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:44:308] [15954:6ee27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:44:308] [15954:6ee27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:44:310] [15954:6ec1b000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:44:312] [15954:6ec1b000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[19:20:44:056] [15955:6c34b000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:44:058] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:44:058] [15955:6c34b000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:44:059] [15955:6c34b000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:44:059] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:44:059] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:44:059] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:44:059] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:44:059] [15955:6c34b000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:44:059] [15955:6c34b000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:44:259] [15955:6c34b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:45:410] [15955:6c34b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:45:561] [15955:6c34b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 477
[19:20:45:561] [15955:6c34b000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:45:563] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:45:565] [15955:6c34b000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:45:577] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:45:592] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:45:592] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:45:592] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:45:592] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:45:592] [15955:6c34b000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:45:623] [15955:6c34b000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:45:623] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:45:635] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:45:635] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:45:635] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:45:635] [15955:6c34b000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:45:635] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:45:649] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:45:663] [15955:6c34b000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:45:663] [15955:6c34b000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:45:663] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:45:663] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:45:663] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:45:674] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:674] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:685] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:685] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:705] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:705] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:718] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:718] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:730] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:730] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:741] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:741] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:752] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:752] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:763] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:763] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:774] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:774] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:785] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:45:785] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:45:796] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:45:797] [15955:6c34b000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:45:797] [15955:6c34b000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:45:797] [15955:6c34b000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:45:797] [15955:6c34b000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:45:797] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:45:810] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:45:810] [15955:6c34b000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:45:810] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:45:875] [15955:6c34b000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:45:876] [15955:6c34b000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:45:876] [15955:6c34b000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:45:876] [15955:6c34b000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:45:876] [15955:6cdaf000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:45:878] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:45:887] [15955:6c34b000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:45:887] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:45:887] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:45:887] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:45:887] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:45:888] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:45:893] [15955:6c34b000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:45:895] [15955:6c34b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:45:895] [15955:6c34b000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:45:908] [15955:6c34b000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:45:908] [15955:6c34b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:45:908] [15955:6c34b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:45:908] [15955:6c34b000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:45:908] [15955:6c34b000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:45:908] [15955:6c34b000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:45:913] [15955:6d3f7000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:45:914] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:45:914] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:45:914] [15955:6d3f7000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:45:914] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:45:914] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:45:914] [15955:6d3f7000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:45:914] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:45:914] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:45:914] [15955:6d1eb000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:45:916] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:45:916] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:45:928] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:46:289] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:46:289] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:46:289] [15955:6d1eb000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:46:289] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:46:289] [15955:6d1eb000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:46:289] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:46:301] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:46:301] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:46:313] [15955:6cdaf000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:46:314] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:46:314] [15955:6d1eb000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:46:382] [15955:6cdaf000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:46:382] [15955:6cdaf000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:46:382] [15955:6cdaf000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:46:382] [15955:6cdaf000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:46:382] [15955:6d3f7000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:46:382] [15955:6d3f7000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:46:383] [15955:6d3f7000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:46:383] [15955:6d3f7000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:46:384] [15955:6d1eb000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:46:385] [15955:6d1eb000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[19:20:46:127] [15956:6db27000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:46:129] [15956:6db27000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:46:129] [15956:6db27000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:46:129] [15956:6db27000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:47:330] [15956:6db27000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:47:482] [15956:6db27000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:47:632] [15956:6db27000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 505
[19:20:47:632] [15956:6db27000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:47:633] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:47:635] [15956:6db27000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:47:647] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:47:664] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:47:664] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:47:664] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:47:664] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:47:664] [15956:6db27000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:47:694] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:47:694] [15956:6db27000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:47:694] [15956:6db27000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:47:694] [15956:6db27000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:47:695] [15956:6db27000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:47:695] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:47:707] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:47:707] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:47:707] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:47:707] [15956:6db27000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:47:707] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:47:720] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:47:720] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:47:720] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:47:721] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:47:733] [15956:6db27000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:47:733] [15956:6db27000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:47:733] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:47:733] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:47:733] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:47:745] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:745] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:757] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:757] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:768] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:768] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:780] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:780] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:791] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:791] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:802] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:802] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:814] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:814] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:825] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:825] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:837] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:837] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:847] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:47:848] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:47:859] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:47:859] [15956:6db27000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:47:860] [15956:6db27000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:47:860] [15956:6db27000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:47:860] [15956:6db27000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:47:860] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:47:873] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:47:873] [15956:6db27000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:47:873] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:47:965] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:47:965] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:47:965] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:47:965] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:47:965] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:47:966] [15956:6db27000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:47:966] [15956:6db27000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:47:966] [15956:6db27000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:47:966] [15956:6e58b000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:47:968] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:47:981] [15956:6db27000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:47:981] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:47:981] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:47:981] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:47:981] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:47:981] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:47:995] [15956:6db27000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:47:997] [15956:6db27000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:47:997] [15956:6db27000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:47:020] [15956:6db27000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:47:020] [15956:6db27000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:47:020] [15956:6db27000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:47:020] [15956:6db27000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:47:020] [15956:6db27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:47:021] [15956:6db27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:47:027] [15956:6ebd3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:47:028] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:47:028] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:47:028] [15956:6ebd3000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:47:028] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:47:028] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:47:028] [15956:6e9c7000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:47:030] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:47:031] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:47:042] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:47:042] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:47:042] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:47:042] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:47:043] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:47:043] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:48:486] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:48:486] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:48:486] [15956:6e9c7000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:48:486] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:48:486] [15956:6e9c7000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:48:486] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:48:498] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:48:498] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:48:510] [15956:6e58b000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:48:511] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:48:511] [15956:6e9c7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:48:530] [15956:6e58b000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:48:530] [15956:6e58b000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:48:530] [15956:6e58b000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:48:530] [15956:6e58b000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:48:531] [15956:6ebd3000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:48:531] [15956:6ebd3000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:48:533] [15956:6ebd3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:48:533] [15956:6ebd3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:48:533] [15956:6e9c7000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:48:535] [15956:6e9c7000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[19:20:49:291] [15957:6bdb3000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:49:293] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:49:294] [15957:6bdb3000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:49:294] [15957:6bdb3000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:49:294] [15957:6bdb3000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:49:496] [15957:6bdb3000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:49:648] [15957:6bdb3000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:49:798] [15957:6bdb3000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 479
[19:20:49:798] [15957:6bdb3000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:49:800] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:49:802] [15957:6bdb3000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:49:815] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:49:830] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:49:830] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:49:830] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:49:830] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:49:830] [15957:6bdb3000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:49:861] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:49:877] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:49:892] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:49:904] [15957:6bdb3000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:49:904] [15957:6bdb3000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:49:904] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:49:904] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:49:904] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:49:915] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:916] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:927] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:927] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:938] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:938] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:950] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:950] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:962] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:962] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:973] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:973] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:984] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:984] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:996] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:996] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:007] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:007] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:019] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:49:019] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:49:030] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:49:030] [15957:6bdb3000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:49:030] [15957:6bdb3000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:49:030] [15957:6bdb3000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:49:031] [15957:6bdb3000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:49:031] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:49:044] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:49:044] [15957:6bdb3000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:49:044] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:49:127] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:49:128] [15957:6bdb3000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:49:128] [15957:6bdb3000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:49:128] [15957:6bdb3000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:49:129] [15957:6c817000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:49:130] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:49:145] [15957:6bdb3000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:49:145] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:49:145] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:49:145] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:49:145] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:49:145] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:49:159] [15957:6bdb3000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:49:161] [15957:6bdb3000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:49:161] [15957:6bdb3000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:49:185] [15957:6bdb3000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:49:185] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:49:185] [15957:6bdb3000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:49:185] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:49:185] [15957:6bdb3000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:49:185] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:49:185] [15957:6bdb3000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:49:186] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:49:186] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:49:186] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:49:186] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:49:186] [15957:6bdb3000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:49:186] [15957:6bdb3000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:49:193] [15957:6ce5f000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:49:193] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:49:193] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:49:194] [15957:6ce5f000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:49:194] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:49:194] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:49:194] [15957:6cc53000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:49:197] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:49:197] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:49:209] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:50:589] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:50:590] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:50:590] [15957:6cc53000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:50:590] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:50:590] [15957:6cc53000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:50:590] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:50:602] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:50:602] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:50:615] [15957:6c817000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:50:616] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:50:616] [15957:6cc53000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:50:679] [15957:6c817000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:50:679] [15957:6c817000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:50:679] [15957:6c817000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:50:679] [15957:6c817000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:50:679] [15957:6ce5f000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:50:679] [15957:6ce5f000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:50:682] [15957:6ce5f000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:50:682] [15957:6ce5f000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:50:685] [15957:6cc53000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:50:687] [15957:6cc53000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[19:20:51:430] [15958:6ff87000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:51:432] [15958:6ff87000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:51:432] [15958:6ff87000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:51:432] [15958:6ff87000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:51:632] [15958:6ff87000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:51:784] [15958:6ff87000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:51:935] [15958:6ff87000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 493
[19:20:51:935] [15958:6ff87000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:51:937] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:51:939] [15958:6ff87000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:51:951] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:51:966] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:51:966] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:51:966] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:51:966] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:51:966] [15958:6ff87000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:51:996] [15958:6ff87000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:51:996] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:51:008] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:51:008] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:51:008] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:51:008] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:51:009] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:51:009] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:51:009] [15958:6ff87000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:51:009] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:51:022] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:51:035] [15958:6ff87000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:51:035] [15958:6ff87000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:51:035] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:51:035] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:51:035] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:51:047] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:047] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:058] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:058] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:069] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:069] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:081] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:081] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:092] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:092] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:103] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:103] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:114] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:114] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:126] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:126] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:137] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:137] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:149] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:51:149] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:51:160] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:51:160] [15958:6ff87000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:51:161] [15958:6ff87000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:51:161] [15958:6ff87000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:51:161] [15958:6ff87000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:51:161] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:51:174] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:51:174] [15958:6ff87000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:51:174] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:51:260] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:51:261] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:51:261] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:51:261] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:51:261] [15958:6ff87000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:51:261] [15958:6ff87000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:51:261] [15958:6ff87000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:51:261] [15958:6ff87000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:51:261] [15958:709eb000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:51:263] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:52:279] [15958:6ff87000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:52:279] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:52:279] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:52:279] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:52:279] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:52:279] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:52:293] [15958:6ff87000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:52:295] [15958:6ff87000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:52:295] [15958:6ff87000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:52:318] [15958:6ff87000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:52:318] [15958:6ff87000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:52:318] [15958:6ff87000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:52:318] [15958:6ff87000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:52:318] [15958:6ff87000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:52:318] [15958:6ff87000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:52:325] [15958:71033000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:52:325] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:52:325] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:52:326] [15958:71033000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:52:326] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:52:326] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:52:326] [15958:70e27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:52:328] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:52:328] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:52:340] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:52:724] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:52:724] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:52:724] [15958:70e27000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:52:724] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:52:724] [15958:70e27000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:52:724] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:52:736] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:52:736] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:52:748] [15958:709eb000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:52:749] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:52:749] [15958:70e27000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:52:820] [15958:709eb000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:52:820] [15958:709eb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:52:820] [15958:709eb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:52:820] [15958:709eb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:52:820] [15958:71033000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:52:820] [15958:71033000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:52:822] [15958:71033000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:52:822] [15958:71033000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:52:823] [15958:70e27000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:52:824] [15958:70e27000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
[19:20:53:553] [15960:6f657000] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "a********", "a*" (Mstsc) => "Username: "a********" Domain: "a*""
[19:20:53:555] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:53:555] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:53:555] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:53:555] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:53:555] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.channels.channels.cliprdr.client] - [cliprdr_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx cliprdr
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_VirtualChannelEntryEx]: VirtualChannelEntryEx
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx drdynvc
[19:20:53:556] [15960:6f657000] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpdr
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx rdpsnd
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMJump
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMCmd
[19:20:53:556] [15960:6f657000] [DEBUG][com.freerdp.client.common.cmdline] - [freerdp_client_load_static_channel_addin]: loading channelEx RDMLog
[19:20:53:556] [15960:6f657000] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[19:20:53:756] [15960:6f657000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives benchmark result:
[19:20:53:908] [15960:6f657000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * generic= 96
[19:20:53:059] [15960:6f657000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: * optimized= 470
[19:20:53:059] [15960:6f657000] [DEBUG][com.freerdp.primitives] - [primitives_autodetect_best]: primitives autodetect, using optimized
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_set_negotiation_enabled]: Enabling security layer negotiation: TRUE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_set_restricted_admin_mode_required]: Enabling restricted admin mode: FALSE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdp]: Enabling RDP security: TRUE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_tls]: Enabling TLS security: TRUE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_nla]: Enabling NLA security: TRUE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_ext]: Enabling NLA extended security: FALSE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_rdstls]: Enabling RDSTLS security: FALSE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_enable_aad]: Enabling RDS AAD security: FALSE
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_INITIAL --> CONNECTION_STATE_NEGO
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: state: NEGO_STATE_NLA
[19:20:53:061] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: Attempting NLA security
[19:20:53:063] [15960:6f657000] [DEBUG][com.freerdp.core] - [freerdp_tcp_default_connect]: connecting to peer 192.168.10.38
[19:20:53:075] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_send_negotiation_request]: RequestedProtocols: 3
[19:20:53:089] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_process_negotiation_response]: RDP_NEG_RSP::flags = { [0x1f] |EXTENDED_CLIENT_DATA_SUPPORTED|DYNVC_GFX_PROTOCOL_SUPPORTED|RDP_NEGRSP_RESERVED|RESTRICTED_ADMIN_MODE_SUPPORTED|REDIRECTED_AUTHENTICATION_MODE_SUPPORTED }
[19:20:53:089] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_recv]: selected_protocol: 2
[19:20:53:089] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_attempt_nla]: state: NEGO_STATE_FINAL
[19:20:53:089] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_connect]: Negotiated NLA security
[19:20:53:089] [15960:6f657000] [DEBUG][com.freerdp.core.nego] - [nego_try_connect]: nego_security_connect with PROTOCOL_HYBRID
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_INITIAL
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.sspi] - [InitSecurityInterfaceExA]: InitSecurityInterfaceExA
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_init]: Using package: Negotiate (cbMaxToken: 12256 bytes)
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_setup_client]: Acquired client credentials
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_INITIAL
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_INITIAL to NTLM_STATE_NEGOTIATE
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe20882b7] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_NEGOTIATE_OEM|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_LM_KEY|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_NEGOTIATE to NTLM_STATE_CHALLENGE
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Available mechanism: NTLM (1.3.6.1.4.1.311.2.2.10)
[19:20:53:119] [15960:6f657000] [DEBUG][com.winpr.negotiate] - [negotiate_InitializeSecurityContextW]: Using direct NTLM
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication in progress... (output token size: 40)
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [93 bytes]
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_INITIAL --> NLA_STATE_NEGO_TOKEN
[19:20:53:119] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NEGO --> CONNECTION_STATE_NLA
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- nego token
[19:20:53:131] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_read_negotiate_flags]: Read flags [0xe2898235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_TARGET_TYPE_DOMAIN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:53:131] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_CHALLENGE to NTLM_STATE_AUTHENTICATE
[19:20:53:131] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_write_negotiate_flags]: Write flags [0xe288b235] NTLMSSP_NEGOTIATE_UNICODE|NTLMSSP_REQUEST_TARGET|NTLMSSP_NEGOTIATE_SIGN|NTLMSSP_NEGOTIATE_SEAL|NTLMSSP_NEGOTIATE_NTLM|NTLMSSP_NEGOTIATE_DOMAIN_SUPPLIED|NTLMSSP_NEGOTIATE_WORKSTATION_SUPPLIED|NTLMSSP_NEGOTIATE_ALWAYS_SIGN|NTLMSSP_NEGOTIATE_EXTENDED_SESSION_SECURITY|NTLMSSP_NEGOTIATE_TARGET_INFO|NTLMSSP_NEGOTIATE_VERSION|NTLMSSP_NEGOTIATE_128|NTLMSSP_NEGOTIATE_KEY_EXCH
[19:20:53:131] [15960:6f657000] [DEBUG][com.winpr.sspi.NTLM] - [ntlm_change_state]: change state from NTLM_STATE_AUTHENTICATE to NTLM_STATE_FINAL
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Authentication complete (output token size: 532 bytes)
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.auth] - [credssp_auth_authenticate]: Context sizes: cbMaxSignature=16, cbSecurityTrailer=16
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:53:131] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> negoToken
[19:20:53:132] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> public key auth
[19:20:53:132] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:53:132] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [649 bytes]
[19:20:53:132] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_NEGO_TOKEN --> NLA_STATE_PUB_KEY_AUTH
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- receiving...
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- protocol version 6
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_decode_ts_request]: <<----- public key auth
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> sending...
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: ----->> protocol version 6
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> auth info
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_write_octet_string]: ----->> client nonce
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_send]: [135 bytes]
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_PUB_KEY_AUTH --> NLA_STATE_AUTH_INFO
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.nla] - [nla_set_state]: -- NLA_STATE_AUTH_INFO --> NLA_STATE_FINAL
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_NLA --> CONNECTION_STATE_MCS_CREATE_REQUEST
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.gcc] - [gcc_write_client_core_data]: Sending highColorDepth=0x0018, supportedColorDepths=0x000f, earlyCapabilityFlags=RNS_UD_CS_WANT_32BPP_SESSION|RNS_UD_CS_VALID_CONNECTION_TYPE|RNS_UD_CS_SUPPORT_DYNVC_GFX_PROTOCOL|RNS_UD_CS_SUPPORT_HEARTBEAT_PDU|RNS_UD_CS_SUPPORT_SKIP_CHANNELJOIN|[0x00000d22]
[19:20:53:146] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_REQUEST --> CONNECTION_STATE_MCS_CREATE_RESPONSE
[19:20:53:158] [15960:6f657000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_core_data]: Received EarlyCapabilityFlags=RNS_UD_CS_SUPPORT_STATUSINFO_PDU|[0x00000004]
[19:20:53:158] [15960:6f657000] [DEBUG][com.freerdp.core.gcc] - [gcc_read_server_security_data]: Server rdp encryption method: NONE
[19:20:53:158] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CREATE_RESPONSE --> CONNECTION_STATE_MCS_ERECT_DOMAIN
[19:20:53:158] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ERECT_DOMAIN --> CONNECTION_STATE_MCS_ATTACH_USER
[19:20:53:158] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER --> CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM
[19:20:53:169] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_ATTACH_USER_CONFIRM --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:169] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:181] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:181] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:192] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:192] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:203] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:203] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:215] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:215] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:227] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:227] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:239] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:239] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:250] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:250] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:53:262] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:53:262] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:54:273] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST
[19:20:54:273] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_REQUEST --> CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE
[19:20:54:285] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MCS_CHANNEL_JOIN_RESPONSE --> CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE
[19:20:54:285] [15960:6f657000] [DEBUG][com.freerdp.core.info] - [rdp_write_info_packet]: Client Info Packet Flags = INFO_MOUSE|INFO_DISABLECTRLALTDEL|INFO_AUTOLOGON|INFO_UNICODE|INFO_MAXIMIZESHELL|INFO_LOGONNOTIFY|INFO_COMPRESSION|INFO_ENABLEWINDOWSKEY|INFO_FORCE_ENCRYPTED_CS_PDU|INFO_LOGONERRORS|INFO_MOUSE_HAS_WHEEL|INFO_AUDIOCAPTURE
[19:20:54:286] [15960:6f657000] [DEBUG][com.winpr.timezone] - [winpr_get_timezone_from_link]: tzid: Europe/Berlin
[19:20:54:286] [15960:6f657000] [INFO][com.winpr.timezone] - [winpr_detect_windows_time_zone]: tzid: Europe/Berlin
[19:20:54:286] [15960:6f657000] [DEBUG][com.winpr.timezone] - [GetTimeZoneInformation]: tz: Bias=-60 sn='W. Europe Standard Time' dln='W. Europe Daylight Time'
[19:20:54:286] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_SECURE_SETTINGS_EXCHANGE --> CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST
[19:20:54:299] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CONNECT_TIME_AUTO_DETECT_REQUEST --> CONNECTION_STATE_LICENSING
[19:20:54:299] [15960:6f657000] [WARN][com.freerdp.core.license] - [license_read_binary_blob_data]: license binary blob::type BB_ERROR_BLOB, length=0, skipping.
[19:20:54:299] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_LICENSING --> CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST
[19:20:54:375] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_MULTITRANSPORT_BOOTSTRAPPING_REQUEST --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE
[19:20:54:375] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_DEMAND_ACTIVE --> CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_CAPABILITIES_EXCHANGE_CONFIRM_ACTIVE --> CONNECTION_STATE_FINALIZATION_SYNC
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_SYNC] reset finalize_sc_pdus
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x1f size=37 channelId=1012)
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_SYNC --> CONNECTION_STATE_FINALIZATION_COOPERATE
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_COOPERATE] reset finalize_sc_pdus
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x14 size=41 channelId=1012)
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_COOPERATE --> CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL] reset finalize_sc_pdus
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_REQUEST_CONTROL --> CONNECTION_STATE_FINALIZATION_FONT_LIST
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_FINALIZATION_FONT_LIST] reset finalize_sc_pdus
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.rdp] - [rdp_send_data_pdu]: sending data (type=0x27 size=41 channelId=1012)
[19:20:54:376] [15960:6f657000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_FONT_LIST --> CONNECTION_STATE_FINALIZATION_CLIENT_SYNC
[19:20:54:376] [15960:6f657000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Local framebuffer format PIXEL_FORMAT_BGRX32
[19:20:54:376] [15960:6f657000] [INFO][com.freerdp.gdi] - [gdi_init_ex]: Remote framebuffer format PIXEL_FORMAT_BGRA32
[19:20:54:376] [15960:700bb000] [INFO][com.freerdp.channels.rdpdr.client] - [devman_load_device_service]: Loading device service drive [ppk] (static)
[19:20:54:378] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpdr)
[19:20:54:394] [15960:6f657000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [static] Loaded mac backend for rdpsnd
[19:20:54:394] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (rdpsnd)
[19:20:54:394] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMJump)
[19:20:54:394] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMCmd)
[19:20:54:394] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (RDMLog)
[19:20:54:394] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (cliprdr)
[19:20:54:408] [15960:6f657000] [DEBUG][com.winpr.clipboard] - [ClipboardInitLocalFileSubsystem]: initialized synthetic local file subsystem
[19:20:54:410] [15960:6f657000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel audin
[19:20:54:410] [15960:6f657000] [DEBUG][com.freerdp.channels.audin.client] - [audin_register_device_plugin]: device registered.
[19:20:54:432] [15960:6f657000] [INFO][com.freerdp.channels.audin.client] - [audin_load_device_plugin]: Loaded mac backend for audin
[19:20:54:432] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 1
[19:20:54:432] [15960:6f657000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel ainput
[19:20:54:432] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 2
[19:20:54:432] [15960:6f657000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpsnd
[19:20:54:432] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 3
[19:20:54:432] [15960:6f657000] [INFO][com.freerdp.channels.drdynvc.client] - [dvcman_load_addin]: Loading Dynamic Virtual Channel rdpgfx
[19:20:54:433] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_register_plugin]: register_plugin: num_plugins 4
[19:20:54:433] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 1.AUDIO_INPUT.
[19:20:54:433] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 2.FreeRDP::Advanced::Input.
[19:20:54:433] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 3.AUDIO_PLAYBACK_DVC.
[19:20:54:433] [15960:6f657000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_listener]: create_listener: 4.Microsoft::Windows::RDS::Graphics.
[19:20:54:433] [15960:6f657000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (drdynvc)
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Synchronize Data PDU (0x1F), length: 22
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_SYNC] received flag FINALIZE_SC_SYNCHRONIZE_PDU [0x00000001]
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_SYNC --> CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Control Data PDU (0x14), length: 26
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE] received flag FINALIZE_SC_CONTROL_COOPERATE_PDU [0x00000002]
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_COOPERATE --> CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL] received flag FINALIZE_SC_CONTROL_GRANTED_PDU [0x00000004]
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_GRANTED_CONTROL --> CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_recv_data_pdu]: recv Font Map Data PDU (0x28), length: 26
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_set_flag]: [CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP] received flag FINALIZE_SC_FONT_MAP_PDU [0x00000008]
[19:20:54:440] [15960:70703000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_FINALIZATION_CLIENT_FONT_MAP --> CONNECTION_STATE_ACTIVE
[19:20:54:440] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=3 ChannelName=Microsoft::Windows::RDS::Telemetry
[19:20:54:441] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Telemetry'
[19:20:54:441] [15960:70703000] [DEBUG][com.freerdp.core.heartbeat] - [rdp_recv_heartbeat_packet]: received Heartbeat PDU -> period=1, count1=8, count2=8
[19:20:54:441] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=7 ChannelName=Microsoft::Windows::RDS::Graphics
[19:20:54:441] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener Microsoft::Windows::RDS::Graphics created new channel 7
[19:20:54:441] [15960:704f7000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (Microsoft::Windows::RDS::Graphics)
[19:20:54:444] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:54:444] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 7
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=9 ChannelName=Microsoft::Windows::RDS::Video::Control::v08.01
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Control::v08.01'
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=10 ChannelName=Microsoft::Windows::RDS::Video::Data::v08.01
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Video::Data::v08.01'
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=11 ChannelName=Microsoft::Windows::RDS::Geometry::v08.01
[19:20:54:456] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'Microsoft::Windows::RDS::Geometry::v08.01'
[19:20:54:811] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=18 ChannelName=AUDIO_PLAYBACK_DVC
[19:20:54:811] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_create_channel]: listener AUDIO_PLAYBACK_DVC created new channel 18
[19:20:54:811] [15960:704f7000] [DEBUG][Devolutions.Rdp] - [_OnChannelConnected]: OnChannelConnected (AUDIO_PLAYBACK_DVC)
[19:20:54:811] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: channel created
[19:20:54:811] [15960:704f7000] [INFO][com.freerdp.channels.rdpsnd.client] - [rdpsnd_load_device_plugin]: [dynamic] Loaded mac backend for rdpsnd
[19:20:54:811] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [dvcman_open_channel]: open_channel: ChannelId 18
[19:20:54:823] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=AUDIO_PLAYBACK_LOSSY_DVC
[19:20:54:823] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'AUDIO_PLAYBACK_LOSSY_DVC'
[19:20:54:835] [15960:700bb000] [DEBUG][com.freerdp.channels.rdpdr.client] - [rdpdr_process_server_announce_request]: [rdpdr] server announces version 1.13, client uses 1.13
[19:20:54:836] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: process_create_request: ChannelId=19 ChannelName=RDCamera_Device_Enumerator
[19:20:54:836] [15960:704f7000] [DEBUG][com.freerdp.channels.drdynvc.client] - [drdynvc_process_create_request]: no listener for 'RDCamera_Device_Enumerator'
[19:20:54:952] [15960:700bb000] [WARN][com.freerdp.channels.rdpdr.client] - [devman_get_device_by_id]: could not find device ID 0xffffffff
[19:20:54:952] [15960:700bb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_irp]: irp_new failed with 87!
[19:20:54:952] [15960:700bb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_process_receive]: rdpdr_process_irp failed with error 87
[19:20:54:952] [15960:700bb000] [ERROR][com.freerdp.channels.rdpdr.client] - [rdpdr_virtual_channel_client_thread]: rdpdr_process_receive failed with error 87!
[19:20:54:952] [15960:70703000] [ERROR][com.freerdp.core] - [checkChannelErrorEvent]: rdpdr_virtual_channel_client_thread reported an error. Error was 87
[19:20:54:952] [15960:70703000] [ERROR][com.freerdp.core] - [freerdp_check_event_handles]: checkChannelErrorEvent() failed - 0
[19:20:54:954] [15960:70703000] [DEBUG][com.freerdp.core.rdp] - [rdp_finalize_reset_flags]: [CONNECTION_STATE_ACTIVE] reset finalize_sc_pdus
[19:20:54:954] [15960:70703000] [DEBUG][com.freerdp.core.connection] - [rdp_client_transition_to_state]: CONNECTION_STATE_ACTIVE --> CONNECTION_STATE_INITIAL
[19:20:54:958] [15960:704f7000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (Microsoft::Windows::RDS::Graphics)
[19:20:54:960] [15960:704f7000] [DEBUG][Devolutions.Rdp] - [_OnChannelDisconnected]: OnChannelDisconnected (AUDIO_PLAYBACK_DVC)
Sorry, this is the complete one
Hello
Thank you for the information.
On first glance, it seems that there might be a problem redirecting resources to the remote machine. What options do you have selected in RDP > Local Resources > Local Devices and Resources?
You might try next unchecking everything in that section and see if the connection works. This will be a good point to start troubleshooting.
Let me know if something isn't clear.
Thanks and kind regards,
Richard Markievicz
After i have unchecked everything the issue is the same
Hello
Thanks for the update. By any chance, can you provide an updated session log with all those options unchecked?
I'm still working to reproduce the problem on my side.
Richard Markievicz
Hello again
I've done some more digging here; the RDP server is sending an I/O request for a device on your client that isn't properly registered. Previously, this wasn't handled as an error but an update to one of our dependencies has transformed this condition to an error that prevents the connection from proceeding. So I've identified why you can't connect (and to reiterate - it is a regression on our side) but the reason this condition exists is not clear to me.
It appears to me from the earlier log that you are forwarding one drive or directory to the remote machine ("ppk"?). Just to double-check: can you confirm that if you disable "Local Devices and Resources > Hard Drives" and all sub options ("Redirect all disk drives", etc), the connection still does not work?
In that case, an updated session log with those options disabled will be really important to understand what's happening here.
Please let me know if something isn't clear or you have further questions
Kind regards,
Richard Markievicz
Anything is deactivated
