Default Editor - Globally / Per Entry
Absolutely love this software, one nice feature would be able to change certain items on a per entry basis or even globally, such as the default editor, to be able to change it to say VSCode without having to change the default in the local system, software like Putty and WinSCP do allow this.
All Comments (1)
Could you describe the way you are using RDM currently, and what you would like to achieve, with more concrete details? Maybe with screenshots to help follow along, as I would like to be sure I correctly understand your request.
We currently support batch editing (https://help.remotedesktopmanager.com/commands_batchedit.html), and some settings have default values that can be inherited through folders, set in the system settings, or even through local options. Not to mention we also have a Powershell module if you want to script any mass changes in your database. I'm not sure if any of these features would help you in your situation so the more information you can give, the more it will help us.
Closed
