unknown entry in private vault?
Hi!
I just got the info, that at least two colleagues have an unknown entry in their private vault - created by 'unknown'?!
RDM version is 2022.3.35.0 on the pc of the colleague that asked me what's about this entry and if I had it too ...
Any ideas where this one could come from?
Thank you!
Clemens
Hello Clemens,
From my understanding, this behavior could be caused by creating the entries with Devolution Web Login, or perhaps they were created using PowerShell?
Let me know if this helps,
Samuel Dery
Hi Samuel,
thank you - I think Devolutions Web Login could be a good starting point! ;) I just asked my colleague to experiment with this feature as I don't actually use it ...
I'll inform you about news! ;)
Clemens
Hello Clemens,
Thank you for your reply,
No problem,
Let me know if you have further questions,
Samuel Dery
