Copy and Paste from local machine to any RDM host does not work - RDM version 2023.1.20.0 64-bit
HI, I dont seem to be able copy and paste files between local machine and any remote servers.
I have got the local resourse "Hard drives" and is set to all.
I can copy and paste text just not files.
Rdp version tried >latest , FreeRDP latest, I have got it work on 8.1 but then failover manager doesnt right click (which i was advised to use FreeRDP).
Any ideas?
All Comments (1)
Hello TDMPro2K,
Thank you for contacting us on that matter.
Which version of RDM and what type of Data Source you are currently using?
What kind of files are you trying to copy/paste?
Are you trying to copy from your workstation to the RDP session?
I did some tests with normal files like .zip and .exe and I cannot reproduce this issue.
Could you send some screenshots for us?
Patrick Ouimet
