How to use RDM for an entire company, to be used inside and outside of company's private network?
Resolved
I have downloaded a free 30-day trial of the Remote Desktop Manager, in order to decide whether or not to use it for the entire company I'm working for. The background idea is to have one tool, which every colleague can just start up and use for connecting to remote desktops.
In order to do this, I see two challenges:
  1. The RDM information (list of RDM sessions, together with their VPN configuration) is stored on my local computer, it should be possible to import this from a central data source.
  2. Quite of the remote desktop connections require a VPN connection, based on VPN related software. This can be "Pulse Secure", "Microsoft VPN", "WatchGuard", "Forticlient", ...
Solutions:
  1. I can very well imagine there's an easy way to modify the location of the directory from "C:\Users\Username\AppData\Local\Devolutions\RemoteDesktopManager" to some central location, that should not be a problem.
  2. That might be an issue: all that software is installed locally and I believe it must be installed locally in order for it to work. However, one of the reasons I'm working with this trial is to get a "single-button-click" solution for all my colleagues, relieving them from the burden of constantly needing to install extra software on their system.
Now I have two (sorry, three) questions:
a. What about my second "solution"? How can the corresponding situation be tackled?
b. Are there any more things to consider?
c. While checking Connections.db using a simple text editor, I noticed that using the same password for two different Remote Desktop Sessions, the <SafePassword> tag seems to contain the same password, making it very vulnerable for hackers. Are there ways to improve the security of the passwords?
Thanks in advance
All Comments (4)
Hello Scampsd,
Thank you for contacting us on that matter.
Remote Desktop Manager seems to be complex at first with all the features, but where RDM shines the most, is that this is a user-friendly application.
1- If you have access to both data sources in RDM, you could copy the whole vault of your local database and paste it into your other database.
To do so, Select your Local Data Source -> right-click on your vault folder -> Clipboard -> copy (make sure to check the change ID checkbox and include password history) -> OK -> change your data source -> right-click in the navigation panel -> Clipboard -> Paste.
2- Except for Pulse Secure VPN, all the other ones are supported in RDM and can be set to open in pair with your RDP session.
This feature could be set by selecting an RDP entry -> Properties -> VPN/SSH/Gateway.
Please note that this feature could be set by batch edit too.
https://docs.devolutions.net/kb/remote-desktop-manager/how-to-articles/batch-edit-rdm/#batch-edit
In terms of security, if you opted for an advanced data source, you could use a security provider to encrypt your data.
On top of that, you could set an MFA on your data source for more security.
Here you could find more information about it:
https://docs.devolutions.net/kb/remote-desktop-manager/knowledge-base/security-providers-best-practices/
If you are looking for an easy setup for your users (simple-button-click), some of our customers opted for a TS environment. It's a simple installation of RDM where you create the Default.cfg and pushes your master configuration to all of your users.
https://help.remotedesktopmanager.com/installation_terminalservices.html
Patrick Ouimet
