we have an autostart playlist which, since ugrading to 2023.1.14.0 64-bit doesn't load completely anymore. there are three entries, only the first ist loaded at startup. open it manually works, tho..
Hello Perler,
Thank you for reaching out to us.
I understand you're experiencing an issue with your Playlist. Have you tried recreating the Playlist to see if the issue persists?
If the problem persists, could you please provide more information about the type of entry that is being launched? This will allow me to perform some tests on my end to better assist you.
Please let me know if you have any other questions or concerns.
Samuel Dery
playlist is brand new, copied to local from datasource. on another notebook playlist isn't running at all. content is three website entries.
Hello Perler,
Thank you for your reply.
To further investigate the issue you are experiencing, we would appreciate it if you could provide us with some additional information.
Could you please confirm which type of data source you are using?
In addition, could you please provide us with a screenshot of your "Playlist Management" section?
Thank you for your cooperation. Please do not hesitate to contact us if you have any further questions or concerns.
Samuel Dery
