Can you add a warning / confirmation when click “Shift” + Refresh if you have over 10 vaults, I have over 400 then RDM is busy a long time.
Good call, I've added it to our todo list.
Stéfane Lavergne
We've added a default warning when refreshing 10 or more vaults. This option can be modified manually in the .cfg file of your RDM installation to customize the target number (by default 10) for the warning. The name of the option is VaultRefreshCount, and you can change this number by adding the following line:
<VaultRefreshCount>15</VaultRefreshCount>
(In this above case you would have the warning prompted when 15 or more vaults are detected.
This will be available for the 2023.2 version, coming this summer.
Jafran Majeau
