Right click on vm menus not working - Dissappears! Doesnt happen in other RDP Managers
Resolved
So i am just trying out RDM instead of mRemoteNG and Since i have moved i have found that 2019 and 2022 servers i cant right click and see the context menus.
I have gone through and changed all the settings I can see scaling, smart resizing etc and turned them all off. but the issue persists.
Anyone else had this issue? I found some people had issue with Macs, but i cant find anything about it for Windows...
All Comments (8)
So it seems to only affect hyperv Console... failover manager window.
Anyone else had something similar?
Could you confirm your Remote Desktop Manager version? I will have a look on my side.
Best Regards,
Etienne Lord
I am running 2023.1.13.0
So it only happening in failover cluster manager. normal HyperV seems fine.
looked at graphics drivers. aspeed graphics, aswell as microsoft basic display driver.
we have built a fresh new cluster and it affects that too. server 2022 datacenter
This is on different hardware and has a Matrox G200eW3 display driver..
Server 2016 failover cluster manager isnt affected. that works normally..
