After upgrading RDM from 2022.3.29.0 to 2023.1.10 only references for normal entries are shown in the "Referenced By" tab of the overview. References to sub entries aren't listed anymore.
Steps to reproduce
Create Username/Password entry
Create Host entry, link credentials to Username/Password entry
Create another Host entry, create sub entry below this Host entry and ljnk credentials to Username/Password entry for this sub entry
Check "Referenced By" tab for Username/Password entry --> only the first Host entry is listed, the sub entry of the second Host entry is missing
Best regards
Thank you for reporting this issue, we will open a ticket and post back here when we have a fix.
We have completed a fix for this internally.
You should be able to see your sub entries in the "referenced by" section starting from the version 2023.1.14.0 of RDM.
Best Regards,
Michaël Beaudin
I can confirm the fix.
Thank you and best regards!
