If I press Alt+F8, my navigation won't show up. The same if I click View and click the Navigation button.
At the bottom of my screen it shows I have entries. if I double click that it will display my navigation tree in a floating window. This will not however dock for me. Clicking Window, reset layout does not fix the problem. right clicking anywhere in the floating navigation does not give an option to dock.
How can I get my navigation tree to be on the left again?
please try the following steps:
Min
Success!!!!
Thank you, this has been driving me crazy for several versions. I am back to having a docked navigation.
Very much appreciate your assistance.
I'm glad to hear!
Thanks for your feedback 😎
Min
