Need Step-By-Step-instruction for KeePass integration
Hi there,
I don't get it - how do I connect RDM to KeePass?
I am using RDM free (at home) / Team at work for several years now.
And I am using Keepass/Keepass XC for years now.
So, I recently decided to connect my current Version of RDM to my current version of KeePass/KeePass XC just to prevent multiple credential management.
But the only tutorials/howTos/plugins I found deal with older versions of RDM and Keepass.
Even most topics in this board are older than 6 years.
RDM natively offers a KeePass XML Synchronizer-File to connect.
There is no plugin for RDM containing "keepass"
The only way I know, getting a XML-File from KeePass is manually export the database to it.
But this is not "synchronizing".
So I am just overseeing something.
My environment:
Remote Desktop Manager 2022.3.24.0 64 Bit
=> No installed Plugins
=> Database: password-secured SQLite-DB "Connections.db"
KeePass 2.53.1 (64 Bit)
=> No installed Plugins (except Browser-Integration)
=> KeePassDatabase.kdbx
Thank you very much for your help.
Patrick
All Comments (12)
For the KeePass integration, you need to install the KeePass Plug-In installed on your machine.
Here is the article that explain how to integrate KeePass in RDM.
https://kb.devolutions.net/rdm_download_keepass_plugin.html
Let us know if that works.
Érica Poirier
not really.
I found this tutorial in the past.
It's saying you have to install the plugin to the installation-path of keepass.
OK, I did it - several times. Plugin is detected in Keepass.
The main problem is:
3.In RDM create a KeePass entry and validate that the KeePass plug-in is now installed.
I don't have any enty of this type, only the KeePass XML (synchronizer) - which needs a XML-File.
I do not find any possibility to create a new entry which can connect to a kdbx-database.
I also do not find any plugin which would extend the RDM-Session-Types.
I think the solution is quite easy - but I don't get it.
Thank you for your help.
Patrick
What RDM version are you using?
What data source type are you connected to?
The KeePass entry is located in the Credential entries section.
If you are connected to an Advanced Data Source like DVLS or SQL, could you please check in Administration - System Settings - Common - Type Availability if the KeePass entry is checked?
Érica Poirier
Hi again,
as mentioned I am using the following version and datasource:
I am trying this at home with the free version.
At work I didn't try it - there we use PasswordSafe instead of KeePass.
And there we use Remote Desktop Manager Enterprise Edition with a MS SQL-Database
Patrick
Thank you for your feedback.
The KeePass credential entry is only available with licensed RDM application like any other external Credential Managers. It is not available on the Free version.
We will update our online documentation to mention this important information.
Thank you for understanding.
Érica Poirier
Hi Erica,
yes, that is an very important information :-D
Thank you for your time.
Unfortunately I will not be able to test it at work - I am working at a local governmental institution - we are not allowed to use KeePass.
BTW I am really wondering which company uses KeePass as their professional PasswordManager.
Two further questions (sorry):
1) KeePass on old Enterprise (I guess we are customers since 2012) vs new Team-Version: purchase and serial registration
In the past we registered RDM Enterprise Edition Site License with the delivered serial at work within the local installed application at multiple clients - some admins used local datasources, some used local installed MySQL-Databases.
The About-Windows always showed the license and the expiration time (3 years).
Times are changing. In the following years Devolutions experimented a bit with their licensing models.
Now, after changing the versions to TEAM there is no possibility of entering the serial directly into the application anymore.
Even with a puchased license it says free when using a local data source - we had to add a MS SQL-datasource and enter the serial in this source to use functions of the Enterprise Version.
So, just for understanding as we don't use KeePass: If you install the Team-Version with the purchased Enterprise license with a local data source on a notebook (because you are member of the technical field service) and you install keepass - you won't be able to connect RDM to KeePass?
What about other functions depending on the registered version?
2) KeePass XML Synchronizer
May I ask what the "KeePass XML (Synchronizer)" is?
Does it import Keepass-XML-Exports?
Thanks again
Patrick
1) Regarding the licensing, have you tried to add your RDM license in Administration - License? You must only be connected to a SQLite data source or Password Hub personal to have access to the License option in the Administration menu.
2) That's right, the KeePass XML Synch imports XML KeePass exports.
Let us know if you have further questions about it.
Érica Poirier
