Supported Datasources For RDM PowerShell Module?
I installed the newest RDM PowerShell Module from PowerShell Gallery.
I am trying to connect to a MySQL data source, but am receiving the following error:
RemoteDesktopManager.UIService.ShowMySQLLogin(String userName, Boolean userNameEditable, String database, Boolean isOfflinePrompt)
Does that mean the MySQL data source is not supported?
If so, is there a list of supported data sources?
Best regards
All Comments (1)
The MySQL data source is no longer supported with RDM.
https://kb.devolutions.net/kb_rdm_deprecated_data_sources.html
Here is a list of supported data sources you can use. Surely you can find one that offers what you need.
https://help.remotedesktopmanager.com/datasource_types.html
Érica Poirier
