Correct headers for importing SSH/Putty sessions
What are the correct headers to use if I want to import a list of server names and IP addresses, and specify that they are SSH/Putty?
Importing my RDP sessions with just the [NAME][HOST] header worked great.
All Comments (2)
We don't really have something for that directly. What I would do is a kind of workaround that should work fine
1. Create a Putty template with all the settings you want
2. Import all your data as an RDP file
3. Go in Refactoring and use the apply template with the newly created template to convert the RDP session into a putty session
I was just figuring that out when you replied.
I created a template for SSH sessions, them imported a CSV file using the [NAME][HOST] headers, using said template, and it came out perfectly.
