Autofill domain\username in same html control
How is it possible to fill ind our domain\username in the same HTML input?
We have a lot of website that requires us to login using our domain\username in the same input field.
I was unable to find any documentation (or limited information) on this and it's the same about the "Custom Controls" and "Custom Script" login function.
All Comments (2)
you can specify the format in the advanced section from the session properties.
Min
Hi Min
Thanks for the info. This works.
