Display problem with the password generator
Resolved
I use 2022.3.29 and I noticed a strange problem with the password generator.
forum image
The white pop-up is from the blue rectangle. So there is a password, but on some places it is not shown correct. When I click "Generate" again, the problem appears on a different place.
forum image
forum image
One general thing - you should consider your rating about strong passwords. When I generate a 9 letter uppercase password you consider it strong:
forum image
But I don´t think it is:
forum image
How Secure Is My Password? | Password Strength Checker (security.org)
Brgds Andreas
All Comments (4)
Hello Andreas,
Thank you for reporting this issue.
It's a known issue but the fix is not available yet. I will ask our engineering team to raise the priority on this bug fix.
Once a fix will be available, we will post it here.
Thank you for your feedback.
Érica Poirier
Hello Erica,
Thanks for the info! Didn´t know, that it is a known issue. I don´t think that you need to raise the priority. I just wantet to report it as I was unable to find anything about it in the forum and it looks very strange...
Brgds Andreas
Hello Andreas,
The fix for this issue will be available in RDM 2023.1 that should be released in March.
Once available, let us know if that fix works on your end.
Érica Poirier
Dear Erica,
Brgds Andreas
Ends in 4 days
