Buttons in Tabbed Window for RVTools "Default" option don't work
Resolved
Good morning, folks...
When using the RVTools option in "Tabbed" mode, it docks it as it should, but the buttons for the RVTools program do not work when clicked.
You can click on each one and see it turn blue, but it does not drop down the underlying options.
Any other mode other than "Tabbed" works perfectly fine, as RDM doesn't "control" the window.
forum image
Thank you!
--- Chuck
Phoenix, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2022.3.28.0 64-Bit
Password Hub Plugin Personal
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.2.0 64-Bit - Free
All Comments (2)
From my understanding, this would be the expected behavior.
Inside the entry "Properties" you can see a disclaimer mentioning that the applications menu will be disabled while in "Embedded" or "Undocked":
forum image
Let me know if you have further questions regarding this,
Samuel Dery
You know I stared and even read that line three or four times.
It is a pre-holiday week and only Tuesday, so please forgive my stupid questioning on this.
If there was a way to delete the topic I would.
Merry Christmas.
--- Chuck
