Possibillity to add widget pointing to a specific entry in a vault
Possibillity to add widget pointing to a specific entry in a vault, which will open that connection
All Comments (4)
Just to clarify, you would like to have a widget on an android screen that will open rdp and then open a connection from a specific vault?
Best Regards,
Nicolas Dufour
I would e.g. have a RDP connection widget directly on the start screen.
Thank you for your feedback,
Best Regards,
Nicolas Dufour
We have added an option to create a home screen shortcut for a connection in RDM.
To create the shortcut:
  1. Go in RDM
  2. Find your connection in the list, and click on the menu of the connection
  3. Select More to see more options
  4. Click Add to Home Screen, this will prompt you for the widget creation
Maxime Brousseau
