Barcode scanner in handheld unit is not working with Remote Desktop Manager Android in RDP connections
Barcode scanner in handheld unit is not working with Remote Desktop Manager Android in RDP connections.
The barcode scanner is working fine in other apps on the same unit, e.g. Microsoft RD Client or Paralells Client which leads me to believe the problem is in RDM.
All Comments (7)
Do you receive any error messages? Which version of RDM Android are you currently using?
James Lafleur
No, no error messages at all.
The version number of RDM is 2022.3.1.2.
I tested RDM on another unit now, of another brand, and the barcode scanner is working on that one.
Same version (2022.3.1.2)
The Android version on the unit where the barcode scanner is not working is 9, and 8.1.0 on the unit where it is working.
Thank you for your quick reply!
I will transfer this information to our engineering department and get back to you shortly.
Best regards
James Lafleur
When you say that it's not working, do you receive an invalid barcode or nothing at all?
Best Regards,
Nicolas Dufour
Nothing at all
Do you have other bacode devices with version 8.1.0 that you can use and test with?
Best Regards,
Nicolas Dufour
Microsoft's Remote Desktop Protocol does not directly support remote desktop scanning via barcode scanner Android. While you can easily use other peripherals such as printers or external storage devices in a remote session, RDP scanning cannot be accomplished without a third-party USB Redirector.
