Shell copy&pass annoying popup
Hello
How can i disable the popup with (copy/copy all to clipboard/pasre/reset terminal/clear scrollback) in shell conection? .
All Comments (4)
Would it be possible for you to provide me a screenshot of the window you are referring to?
James Lafleur
forum image
it looks like this. I`m opening SSH shell, right click, the content is passed to terminal and this popup appears.
I`d didn`t appear earlier. My RDM version is 2022.3.15.0 64-bit
Could you install RDM 2022.3.23.0?
https://cdn.devolutions.net/download/Setup.RemoteDesktopManager.2022.3.23.0.exe
I know that we made a fix related to the right click in terminal
Thanks. Updated resolved the issue.
Closed
